Ice Maker
I have a Kitchen Aid side by side fridge Model # KSCS25INSS00. I replaced the entire ice maker. Will make one tray(fills, freezes and dispenses, next time it will fill with water, but will not eject the ice. If I take it out and put it back in it works once, then stops again. The freezer temp isThe LED is blinking, and if I close the flapper door it stays solid. Would that mean the board needs replacing too? I know you’ve had similar questions, but I have read if the light stays on when you close the flapper door the beam is working correctly…no? Thanks in advance!
[LEFT][COLOR=#000000]
[/COLOR][/LEFT]
