Ice Maker stopped working
Replaced water valve for ice maker
Ice maker is still not working
Should I replace the second water valve or replace ice maker
Hi.
To produce the ice the temperature in the freezer must be around 0*F. Check that.
Next check if the water supply tube into the icemaker is not frozen. If it is - defrost it.
If it’s not - replace the icemaker[ D7824706Q](https://www.appliancepartspros.com/search.aspx?p= D7824706Q)
Post the results.
Simon.
