Ice melting and refreezing.
My freezer is either getting too hot at defrost or staying in defrost too long as my ice melts and then refreezes. Also water droplets are refreezing in the freezer. Fridge side is working fine. What could be the culprit be Thanks Dave H:confused:
I am having the same issue with my GE side by side. Did you find a fix? Was it the defrost thermostat?
I am having the same issue as well! I posted last night about it and someone replied that the circuit board needs to be replaced. I am hoping this is not the case because I just replaced it about 6 months ago to resolve a different issue!
I don’t think I’m ever buying a GE product again.
With a lot of items in the freezer, the temperature should never get above around 15 degrees.
I would change the defrost thermostat and the evaporator thermister. Defrost thermostat AP3884317, thermister AP3185407
I have th e same issue does anyone have the fix. GE PSC25MSWA SS. Is this a defrost controler pc board or sensor. Unit 2 1/2 years old.
Repost all responses with the boxes filled in with all necessary info.
You are in luck, I just fixed mine… No you are not going crazy and unless you know the right search wrods it is very hard to find the right information when searching the internet. I know this from my experience! I am going to post this on a few more forums so others can find it too…
The freezer has two devices called thermistors that sense the temperature inside. One is usually at the bottom of the freezer and the other is behind the back panel inside the freezer mounted to the evaporator coil. The one that is on the evaporator is probably bad. Typically your freezer goes through a defrost cycle once or twice a day depending on how much the door is open and how long the compressor is running (the controller board monitors this type of stuff). During the defrost cycle, there is a heater that gets energized to melt any ice from the evaporator coil. Once the coil has warmed up, the thermistor at the top of the coil starts to heat up and this tells the controller to shut off the defrost cycle. If the sensor goes bad and reports the temperature as being lower than it really is, the defrost cycle keeps going until eventually it hits some maximum time out and the controller shuts it off even without the sensor reporting that it is warm enough. My defrost cycle seemed to run about 45 minutes before it timed out. When this happens, ice starts to melt and drip down all over everything, ice cream gets soft, frozen juice starts to melt. After the time out, the defrost turns off, the freezer cools down and everything freezes again (ice too, but now it is in a big block).
Thermistors are universal, so they will work in all makes and models. I bought mine on Amazon for $3.30 plus $5.95 shipping.
Check out the following links and it should become clear:
http://www.geservicenet.com/cc/trngprog/Thermistors_Diagnostics.pdf
excellent explanation with specs and pictures.
http://wn.com/How_To_Check_A_Thermistor_On_GE_Refrigerators
Video if you need more hands on…
Hope this helps. DO NOT LET anyone tell you that you need another computer board (also available at Amazon for $110 including shipping) before they show you the resistance readings! Seems like many want you to replace the board before they even check! That is what the repairman who came to my house did, but that is a very upsetting story that I won’t share here! My evaporator thermistor was reading 107 kohms when I checked it… It should have been more like 47.
Good luck!
