I have a GE refrigerator and the ice maker door flap is not opening to let the ice drop down. Everything else works fine. I have removed the solenoid to test it and after applying 120 volts ac it actuated fine so I don’t think that’s the problem. I have also changed the circuit board that the flapper solenoid plugs into and that hasn’t fixed the problem. I assume the micro switch is good because the augar works to push the ice into the door. Any help would be greatly appreciated…
Related topics
GE Ice door flapper not opening | 1 | 1687 | August 20, 2010 | |
Ice door flapper not opening | 2 | 1901 | October 22, 2009 | |
ice shoot flap won't close on ge side by side refrigerator | 0 | 2614 | October 23, 2007 | |
GE SidexSide Fridge Ice Chute Flap stuck and will not open | 1 | 1418 | October 23, 2013 | |
Ice Maker "flapper" doesn't open | 2 | 1678 | August 9, 2009 |
