This icemaker failed while under warranty and was repaired. Worked for another year or two, then stopped again.
No water flows to the mold.
The refrigerator has Ice and Water in the door, and the water dispenses fine. The on/off switch in the freezer is set to on, and the red led flashes.
Any suggestions?
Thanks for the response.
Before I go opening up the refrigerator, does my logic here sound correct.
The red led flashes when the freezer door opens, because the cover on the emiter opens. When I close the cover (unblocking the line of sight between the emiter and reciever) the led stays solid red. Can I conclude that this part of the system is working properly?
My thoughts were a) failure of "sensor" to open the solenoid, b) failure of the solenoid, or c) blockage (frozen) of the water fill tube.
On the last one, the black rubber tube from the interior surface of the freezer is flexible. At one point, there was ice there and the icemaker wasn’t functioning. The ice was removed and the icemaker worked again for awhile.
I would go to the back of the fridge and temporarily swap the plugs on the dual water solenoid. Then dispense water with the fountain switch. If the icemaker fills up, your water supply is ok.
If your freezer temperature is below 15 degrees, you then probably just have a bad icemamaker.
AP3182733
Thermador microwave stops after few second. No erro measge disply on screen. No matter of time of heating setup.
