Icemaker not filling, water valve tests good
The ice maker just stopped working. It seems to work in every aspect except to fill itself up after dumping the ice. I manually filled it and it dumped the ice and did not refill. I tested the water valve by swapping the electrical connector from the door water valve, the water valve worked when activated by the door switch. I put all back together, and need to know what controls the icemaker water valve operation. Any advice would be appreciated.
Joe:confused:
Some icemakers don’t have replaceable parts see if you can look up your ice maker part number and see if your’s is.
