this washer machine has a balance issue. even when it is empty it practically jumps out the door and down the street. the mounts seem to be good and I can see no good reason for the imbalance, anyone have this experience how do I fix it
Hard for us to say since this type of problem requires on site inspection.
You are going to have to delve into it and see if you can discover the problem. Here is a service manual. Note that specifics on your model are at the back.
http://www.servicematters.com/maytag_library/docs/16010061.pdf
I will dive into it, Thanks
