Inner door oven 2 pane glass replacement
The cross section diagram at http://www.appliancepartspros.com or http://www.appliancepartspros.com/partsearch/model.aspx?model_id=239638&diagram_id=23547#d23547
shows 2 #7 or on other models #7 and 10. Part number AP2929316 is the same glass for all similiar models. (AKAW1)
Question: Does the oven door side piece of glass (AKAW1) go up into each corner or does it ride on top of the 2 triangles?
The other top piece of glass is obvious.
The retainer clip for the door piece of glass (AKAW1) has a retainer clip #9 to hold the bottom down. The parts people only had one of these.
When the inner window broke, there was no inner (AKAW1) or 2 bottom clips. I think the previous owner neglected to replace these parts at one time or another.
We want to disable the self cleaning feature to assure no glass breakage again.
