Inner Tube Removal
Im having a hard time removing the inner tub on this machine. I have removed the lock nut with the special spanner wrench and the inner tub is stuck and doesn’t come out. Videos show that it pull right out after removing the lock nut. However, this one is stuck. Please advise on how to remove the inner tub. Thank you!
Hi.
Rock it hard from side to side, use your weight and then yank it up.
Here are the breakdown diagrams and http://www.appliancepartspros.com/03-agitator-basket-parts-for-whirlpool-llr6144aq0.html
Good luck.
Post the results.
Simon.
