Hello,
I am searching for instructions to replace the spray arm assembly (part WD22X154) on my dishwasher. I am not having any luck. Can someone please point me in the right direction or provide instructions? Thank you.
Hello,
Look at the bottom where the spray arm housing goes into the base assembly. The whole spray arm base has retaining tabs, just pry out both to pull spray arm assembly away.
