intermitent clicking and fan function
my fridge keeps cycling the fans (evaperator and condenser) on and off every couple of seconds /minutes randomly
i can hear relay/switch that controls fan in control board constantly cycling/clicking but fridge and freeze is operating fine
repair guy replaced evap fan when diagnostic check suggested it
made no difference repair guy says replace control board with no other checks
could compressor be causing fan relay to cycle intermitent like that and can it be checked, should it be checked
i observed compressor runnig continous and fans constantly cycling
if board is replaced should both fans be replaced if is not the compressor causing issue
Did you get it working?
Was the main board bad?
I have some problem please let me know
