Intermittent F1:E3 error - Oven not working
I have a Kitchen Aid Surperba model KESC307 that is giving me an error code of F1:E3 when I try to start the over. I’ve read up on this in the Internet and found a reset sequence for the control board, but this does not correct the problem. Does anyone know exactly what this error means? I’ve read it has something to do with grounding.
Everything else functions, lights work, control board operates, and stove top is fine.
Note: When I start the oven, the error code comes up immediately or within 10 seconds. If not immediately, the oven does start to heat. I also noticed that a relay on the side of the oven’s control board clicks when the error occurs.
Any assistance would be greatly appreciated.
David
