intermittent gas ignition, igniters or ignitor block?
Puzzling problem, the gas burners work at times and then wont although at times there is small sparks. Would it be the module then?
Once theyre all on then they are easier to tiun back on but if it sits for a while (cools down?) then its a problem to get them started again.
btw, where does the actual clicking sound originate from when the electrode is sparking?
thank you,
Michael
