Intermittent loud humming noise
[SIZE=2]Once or twice a day, my refridgerator starts making this LOUD humming noise. (Can hear it from bedroom on other side of house.) A few minutes later it stops. [/SIZE]
[LIST]
*][SIZE=2][FONT=Arial][SIZE=2]Intermittent noise has been happening for about a month. Earlier this week, it was happening every hour or so, but last few days I haven’t heard it at all.[/SIZE][/SIZE][/FONT]
*][SIZE=2][FONT=Arial][SIZE=2]Other than the noise, the refridgerator seems to be functioning fine.[/SIZE][/SIZE][/FONT]
*][SIZE=2][FONT=Arial][SIZE=2]It’s a WhirlPool (ED5VHGXML10) and about 5 years old. [/SIZE][/SIZE][/FONT]
*][SIZE=2]I can also force noise to stop, by turning the cold control in the refridgerator side lower and higher. [/SIZE]
*][SIZE=2]Ice maker is off. [/SIZE]
*][SIZE=2]Repair man came by and could not reproduce. He said it is likely the starter relay about to go bad, but couldn’t be sure without hearing it.[/SIZE][/LIST]If I want to replace starter relay, what is part number? Is it [AP3601983](http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3083556&pn_=4387835&&model_id=5139641&diagram_id=942008"]AP3083556[/URL] (relay, overload, and cover kit)?
AP3064545AP3040426AP3885081Whirlpool diagram is a little confusing because it lists many individual parts and kits. (e.g. cover , overload , starting device kit, compressor : , and relay start [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3601983&&model_id=5139641&diagram_id=942008).) Will kit AP3083556 serve my needs?
Thanks,
Clarence
[SIZE=2][/SIZE]
Clarence, did you ever figure out what was causing the intermittant loud noise with your [SIZE=3]Whirlpool fridge? I may have the same problem.[/SIZE]
