Is this a timer issue?
Hi–
My washer fills and will agitate only on gentle cycle. It will not drain until it gets to the spin cycle which is supposed to be after the rinse, but of course it’s not spinning and draining until the end, so I have to run that cycle twice.
On normal and permanent press I can sometimes fiddle with the timer and get it to spin, but this is becoming less reliable.
So, new timer and I’m back in business ?
Hi.
Based on the info you provided it does sounds like bad timer
22001026
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26499
Thank you. Post the results.
Simon.
