it's not powering up...
Dryer won’t turn on… checked the wall plug 220V and there is power…
when you open the dryer door the internal light turns ON…
but on the panel it’s all off no sound or anything…
power cable is good all connected… which part might be bad???
Open the console and look for a mini-manual inside. Perform the self diagnosis tests as described there.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5227967
