i have a jenn air model prg4810np , oven works great, but broiler lights ,then goes out, then lights and then goes out, continues, any help please?
Sounds like a weak oven ignitor to me. The ignitor is not strong enough to get the gas valve open. Replace the ignitor. Tom http://www.applianceeducator.com
— Begin quote from kayakcrzy;438607
Sounds like a weak oven ignitor to me. The ignitor is not strong enough to get the gas valve open. Replace the ignitor. Tom ApplianceEducator.com
replaced ignitor, broiler went on , and gfi on wall pops, customer said this happened with other ignitor, plugged in other outlet to bypass gfi, then turned on broiler, broiler lit then started popping, so i turned off. please help if any ideas
