When my oven wouldn’t heat I removed it and opened up the back to check on things. I discovered that there was a short on the terminal block and the control board mounted to the block was charred. I can find the terminal block to order, but I cannot find the control board that was mounted on the block. Can anyone offer any help? I’m not an expert so I’m also open to any other advise.
I’ll attach a photo of the terminal block with mounted control board.
Thanks!
Brian
