Jenn Air cook top CCG457 LP Conversion kit
I have acquired a used Jenn Air CCG457 cook top, and it came with Nat gas spuds. I am looking to convert to LP. I understand the same model is made for LP and is CCP457, so really all I need is the spuds for that model. I cannot find them on the parts diagram, they are not listed seperately, as they must come installed in the burner valve? None the less, their are 4 different sizes, and I could tell you what numbers they are if that helps.
thanks
Jim
