Jenn-Air Cook Top Element Problem
Hello
I have a problem with my stove. The right front element when turned on will come on, but promptly turn off when the hot indicator light comes on. It will stay off until the element cools down and the light goes off. Then it will light again with the same sequence. I have replaced the infinate control switch, but that has not solved the problem.
Any help would be much appreciated
Ed
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JES9900BCW
My guess would be that the element (Item 17 in Section 3) needs replacing.
Perhaps it’s built in thermal protect is opening too soon.
If you click on the picture a new page will pen with a Q&A section, looks like you will need your serial number to get the correct part.
The parts list does include a wiring diagram but it is pretty blurry so here is a better copy.
Although it is for a JES9900BAS, it should be close to yours.
I would check the wiring to the element before ordering just to be sure that something has not shorted out.
Thank you for your reply.
I will check it out.
Regards
Ed
