Jenn Air Cook Top
I am having a problem getting parts information and installation information about my Jenn Air electric cook top and I am hoping you can assist me.
I have a Jenn Air JED 8230 ADB electric cook top. The left side only ( as you face the unit) has an "intermittent heat problem. I have replaced both "infinite" switches and tightened all exposed electrical connectors on the coil element cartridges. The intermittent heat problem is only when I use the coil element cartridges. When I use the "grill element only" the heat is constant and it works fine.
If I "prop up" one side of the cartridge with a piece of aluminum foil where it raises one side of the cartridge while plugged in, the burners work fine.
I have interchanged the "coil element cartridge’ ( I have two of them ) and the heat intermittent problem continues.
Can you advise me what is causing the intermittent problem?
Thank you
Bill Walters
http://b.walters@iquest.net
How many prongs are on each cartridge?
Four total. Three flat spades and one round spade. These are in the coil cartdidge.
Grille cartridge has 3 flat spade connectors and one round connector. The round connector is off-set one space from the cartridge spades.
The numbers on the bottom of the cartridge are: Model A-100
OR CAE1000ACX OR A-100C
I believe the grille cartridge and the coil cartridge have different wiring diagrams. The model number A-100 is for the coil cartridge. What is the model number of the grille cartridge?
Gene,
Thanks for all your help. I’ll check the recepticle out.
