I have a Jenn-Air CCE3401B cooktop that has a cracked glass that I am going to replace. This seems fairly simple, I figured since I am getting in to the unit, I am going to go ahead and fix the back right burner that has not worked for the past 3 months.
I am not sure what parts I need to order, when I turn the know for this burner, the red indicator lights that surround the knob turn on. The burner itself does not turn on. Is this most likeley the burner or some other part / issue?
Thank you in advance for your recommendations!
