Jenn air error code F1
I am receiving a F1 error code along with an audible beep. This requires a reset at the power supply. This returns the unit to a functional state for a brief time. Can you tell me what to test or what the code means?
Hello.
F1 error code means - bad control board. There is no tests required, basically you need to replace the control board.
See the attached diagram #2, position #2.
The control board AP4397547
Her are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45375
Please post results.
