Jenn Air F-5 code
Hi, After a lightning strike my display malfunctioned on my convection oven and also giving me an F-5 code. I replaced the electronic control assembly/clock display. Now the display is working fine but I sstill get the F-5 code. My next step was to replace the relay board. Anyone know anything else I may be able to check on this unit? Thanks!!!
According to the [AP4009009](http://www.servicematters.com/maytag_library/docs/16010312.pdf"]Service manual[/URL] the "F5" error code means "Power element relays disabled in cook mode". The manufacturer recommends to check the oven sensor and its wire harness first. If there is nothing wrong then the relay board has to be replaced.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=677041&&model_id=42800
Thanks a ton Gene. Looks like its the relay board.
You are welcome. Keep us posted.
Gene, You are the man. The relay board got us up and going again. Thanks!!!
