Hello all,
I have Jenn Air fridge JSD2690HES and the control panel on the outside that is used to select water, ice, etc. has cracked and finally broken through. I can still use the controls but am directly touching the button on the circuit board, so I obviously want to get this fixed. I have looked through the parts list and cannot identify the exact part I need with confidence. Here is a picture of it. You can see the circuit board and button behind the black plastic cover/panel that I need to replace. If someone could let me know the part I need, I would really appreciate it so I can get it on order.
Thank you.
-Chad
