Jenn-Air front right dual element won't back off high
Hi,
We have a electric cooktop range that is having an issue where the front right element only heats to a high level and will not back down when a lower level of heat is dialed in. This element is different than the other three in that it is a dual function element that heats an inner/outer coils.
I believe the control switch for this element is bad, but am confused with what I need to order. Is it an infinite switch or control switch? Are these referring to the same part? I found a part listed here that is called a dual element switch and I’m guessing that is what I need but I’d like to see if anyone has an opinion before I order it.
Thanks.
