Jenn Air oven door does not close all the way
Hello, I have seen this issue mentioned a bunch of times, and it seems like everyone says it is an issue with the hinge and hinge receptacle.
I have a double wall oven model JJW9630DDS. One of the oven doors will not close all the way and you can see into the oven (and it doesnt even hit the light switch). I have seen mention of a technical bulletin, but I never seem to be able to see the bulletin.
Can someone point me in the correct direction on what I need to fix this issue?
Thanks for your help in advance
