I know this subject has been discussed before, however is there a solution for an oven, approx two years old where the hinges have been replaced twice and the door has never stayed closed?:mad:
I am about to purchase my third set of hinges and the plan is to somehow make the springs stronger before putting them in.
Can anyone offer an alternative to fix this problem?
You can find an explanation, cause and solution on this problem in the [B]Maytag Technical bulletin[/B]. If you need the correct part number for the kit then post the serial number of the oven.
I’m having issues with door not making tight seal…found this old thread but the link to the Maytag Technical Bulletind is no longer valid. Does anyone still have or know how to get correct part no for the hinges for
