my jenn-air, modle svd48600b, is limited in operation. the electronic oven control assy just recently went completed out. before going completely out, meaning no indication at all, i would receive a beeping sound followed by an appliance fault code with the lighs dimming on the electronic oven control assy. the broil function will not work but the bake will. the broil convention fan will not work when i’m in the broil function. i forget what the appliance fault code was but i think it was f6. f6 is not listed on the appliance fault code list. the fault code would only come on when i am baking in the oven. i would reset the fault code by reseting my home circuit breaker. after resetting and using the over, the fault code will reappear.
need some advice…
