Jenn-Air Oven short?
Have an old Jenn-Air (model number above).
About 3 months ago, the panel had a short and would not function. I replaced the panel and clock and the oven worked fine.
Just last weekend, the clock and panel buttons ceased to work as well as all the heating elements. All was working fine when suddenly it all stopped.
HOWEVER, if I turn on the top burner via any of the knobs, the clock displays and the panel buttons begin to work … but only when the one of the burner knobs is turned on. No heating elements will work, even though I can get the panel and burner knob lights to come on. I can set the oven to bake or broil. On broil, the fan will turn on but heating element will not heat up.
I understand it is probably a short somewhere. But what might need replacing? The panel is brand new as is the clock. All other parts are at least 10 years old.
