Jenn-Air range with natural gas cook top and electric oven. The top broiler element heats, but the bottom bake element does not. The bottom element sounded like and looked like, it had a blowout, popping the circuit breaker. I replaced the bake element and it continues to not heat. :eek:
— Begin quote from Winkelman;268459
Winkelman,
I take for granted,
You’re sure you reset both breakers ?
Most likely,
You also shorted out the bake relay on the relay board, in the back of the machine, or a burnt / damaged wire, behind the back panel on the range.
Drop us a line if you need more assistance.
