Jenn - air radiant cooktop
I would like to now how to install a replacement element part#74010156 for a Jenn-Air Radiant Cooktop.
Thank you,
Walter
[SIZE="4"]DUPLICATE[/SIZE]
Please see the following
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/256932-cooktop.html
booger
I do not know what link you are talking about.
If you mean the link in this post then I tried it and it works for me.
If you mean the links in the post that this post points to then the second link in that post does work. At least it works for me.
— Begin quote from ____
[LEFT][COLOR=#000000]denman booger
[LEFT]I do not know what link you are talking about.
If you mean the links in the post that this post points to then the second link in that post does work. At least it works for me. Read more: [Download JEC0530.pdf](http://forum.appliancepartspros.com/newreply.php?do=newreply&noquote=1&p=475734#ixzz1QeNaBFGj http://forum.appliancepartspros.com"]http://forum.appliancepartspros.com/...epartspros.com[/URL] [/LEFT]
Read more: http://forum.appliancepartspros.com/newreply.php?do=postreply&t=257599#ixzz1QeQiqIoa
http://forum.appliancepartspros.com [/COLOR]
[/LEFT]
Data File Host[LEFT][LEFT][COLOR=#000000][COLOR=#000000]Yes I must of just tried the first one. which stated The file you requested (id 258ef303) does not exist. It might have been deleted due to inactivity (no downloads) or due to not complying with our terms. But indeed you are right the second one works [URL="http://www.datafilehost.com/download-f2d72e61.html) with JECO530 Downloaded 3 times File: JECO530.pdf Size: 3.09 MB… You are all over it denman. Thanks as I had the same problem! You guys really are great and appreciated. Booger JEC0530[/COLOR][/LEFT]
[COLOR=#000000]
[LEFT]Read more: http://forum.appliancepartspros.com/newreply.php?do=postreply&t=257599#ixzz1QeQu6txp
http://forum.appliancepartspros.com [/COLOR][/LEFT]
[/COLOR]
[/LEFT]
[SIZE=3]I have an Amana fridge with the freezer on the bottom. We have had it for over 10 years and have never had any problems, until now. A couple weeks ago the fridge seemed to be getting warm and then the freezer followed in a couple days. At this point we didn’t think the fridge was getting warm we knew it was more than just the door being left open. I vacuumed all the coils behind the front kick plate and turned the fridge and freezer dials up to 6. The next day had no improvement. I unplugged and took off the panel on the back of the fridge and inside the freezer. I vacuumed the back of the fridge. Behind the panel in the freezer was a solid block of ice encasing the coils and blocking the vent to the fridge. I defrosted with a hair dryer. Put everything back together, and left the dials at 6. A week and a half later the air flow was down and the fridge was starting to warm. I put my hand in front of the vent at the back top of the fridge and opened the freezer door and the air flow increased, confirming a air flow blockage. I read online that to pour some warm water down the vent in the back corner at the BOTTOM of the fridge would fix the air flow problem. It did. I also read that the dials should be at 4 so I did this also to both. Now about a week later I noticed the air flow is slow again, which means the temp will be going again, again I poured some warm water down the back corner vent in the bottom of the fridge, and the air flow increased. I don’t want to keep messing with this, so I would like to know what is probably broken. The fans work. The compressor turns off and on, though it might be running more often, but I don’t know, I am just paying attention now. (It hasn’t had a problems in 10+yrs, so I never paid attention to how long it was “on” before.) I believe I have heard a distinct click when the compressor turns off but nothing else of notice. I haven’t taken the back panel in the freezer off yet, but in general the inside of the freezer is free of frost. I am assuming something wore out because this vent being blocked is new, so something isn’t working right anymore. What is a part or two I could replace to solve this issue so I don’t have to keep messing with it weekly? Thank you.[/SIZE]
