Jenn-Air ribbon cable
I’m getting intermittent F1-7 & F1-8 errors and inconsistent beeping, so I’m trying to determine if the problem is with the clock or the touchpad. I read somewhere that if I disconnect the ribbon cable between the two and re-power the range, and there is no further beeping, the problem is the touchpad. Conversely, if the beeps continue, the problem is with the clock assembly.
My immediate problem is removing the ribbon cable; does it pull out of the clock assembly with the black plastic end as part of it, or does the end of the ribbon cable pull out of the connector? I’m afraid to pull too hard and be in a worse situation than I now am.
Thanks…Steve
