Jenn Air Slide In Range Control Panel / Display
Hello all. I had a dim display on my jenn air slide in downdraft range and over time it went completely blank.
I read an old post on this forum about someone replacing a capacitor on the panel to restore the display.
The other day I pulled the panel and there are three capacitors - a C3, C6 and C7.
The C3 is a 47UF 250V, the C6 is a 680UF 25V, and the C7 is a 220UF 50V. I have not desoldered and tested these caps yet but wondering if anyone here knows which one is for the display? The control panel part number is WP8507P232-60.
Whirlpool WP8507P232-60 Cntrl-Elec - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2295-jenn-air-wall-oven-display-3.html#ixzz4wiz1oQtb
http://www.appliancepartspros.com
If you can pull them and test them, do that, or just replace all three.
