Jenn air TC507 Trash comp. manual gear rotation
The ram on my TC507 is stuck in the down position. I removed the bottom and the large plastic gear is broken in half. The chain is on the metal gears. I tried to turn the metal gears by hand but they are not moving. How do I rotate the gears manually to get the ram up? Any help you could provide would be appreciated.
Thanks,
Brenda
