Jenn-Air Oven (JJW9130DDB)
The right-most buttons have stopped responding (3, 6, 9 and oven light). The rest of the touch pad is working normally.
I’m trying to find out if I should order a new Control Panel, or a new Control Clock (the electronics behind the panel) they are both they same price - about $150 (each). I am told that I cannot return them once I get them.
Any advice?
You may not have to order any parts.
You will notice that all the keys you mentioned use track 10 on the ribbon cable as a common, could be this connection is just dirty.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
Could also check it with a meter.
Check from track 10 to other no good key tracks as it may be a crack on the ribbon cable that you cannot see or on the actual keypad itself
If no good then it is a keypad problem.
If OK then it could be the control board
Odds are high that this is a keypad/connection problem.
I have the exact same issue on jenn air jjw8130dds
I followed your instructions and removed the ribbon cable and cleaned it. I reseated the cable and have the same issue. The 3, 6, 9, and oven light are not working.
Also wondering the same question, what part to replace?
THANK YOU!! This worked for me! The two top rows of the numeric keypad were not responding, but cleaning the ribbon cable connection fixed it.
I initially checked all the connections and even swapped out the control board with a spare. I figured it was probably either the ribbon cable or the keypad as the problem remained after the swap.
I then pulled the ribbon cable and cleaned its connectors and those on the control board with 99% alcohol. Powered it up…and it worked!
— Begin quote from denman;127636
Unplug the unit
Open it up
