Jenn-Air warm refrigerator section, freezer fine
Had Ice on coils, tested defrost heater, was okay. Replaced Defrost timer control. Freezer gets cold (-10), refrigerator cools to 40~50 off and on.
Controls for refrigerator, freezer are all set to max (all the way to the right). Evaporator fan seems to be running okay.
Suggestion are welcomed.
:slight_smile:
Jc
JC,
The refrigerator cools down with the cold air coming from the freezer. You have to check the window between thees sections for any obstructions. Make sure the air gate is operated properly.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46183
Where is the air gate on the schematic?
