Jenn Aire control panel failure
My JennAir convection oven control panel has stopped working. You can enter numbers and a couple of the "buttons" almost work but you can’t complete any function and you get no response to most buttons. The buttons are apparently capacitive buttons embedded in a glass panel. No movement, no click, no readings when you put a voltmeter on the flatcable connections to the PCB (the control board). I am confident the problem is either the control board or the glass panel. I think it is the control board.
The original part number for the control board is 202801A but on line sources say that has a new number PS119188. The glass panel is PS505758. This is an old unit and replacements may not be available. I need to know my options. the oven worked perfectly until the control panel stopped taking commands.
