JennAir Oven Only Works With Stove Burner On
Hi:
I have a Jenn-Air stove / oven JGR8875QDS with the following problem.
The oven will not light, or sometimes re-light while in use, unless one of the stove top burners are on.
Turn oven on, igniter glows but oven will not light. If you turn one of the stove top burners on then the oven will light.
I replaced the igniter with no change.
The broiler seems to be working fine.
Is it possible the oven safety valve is going out or maybe I got a defective igniter or ??
Thank you for any help!
tsmithak
