washer will not spin, is there a belt that operates this?
There is, but usually it is the thrust bearing assembly that causes it not to spin.
Here is a Maytag tech bulletin on the parts
http://appliancejunk.com/ge/washer/31-10008.pdf
and here is a service bulletin for models like yours which will show you how to open it up and check the belt and other areas.
http://www.servicematters.com/maytag_library/docs/16023083.pdf
