Freezer quit working. There is a clicking noise every 5 minutes or so. We turned off, defrosted and tried starting it back up. When we turned it on, we could hear it hum, then it clicked and quit humming. Any ideas where to start trouble-shooting?
You probably have a bad start device/relay AP2136233, however it is an item that does’nt fail too often, but worth a try. Retain the thin overload klixon, just replace the relay and make sure the run capacitor is wired in . You will need to pull off the cover on the side of the compressor to do this.
