My wife noted that last few times our wash machine has run, the fabric softener dispenser is leaking out of the machine. There is a dispenser in the front right of the machine. Its draining straight down out of the front of the machine. I haven’t run it yet to see at what point its draining. Thoughts on what to check/repair?
Take off the cabinet and you should be able to easily see the problem.
Here is a site which will show you how. Note that the screws which hold your console on are probably under end cap trim pieces which snap off.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
