I have a kenmore 80 series washer model 110.23832100. The timer goes through the entire cycle but the washer only goes through the wash cycle. No rince or spin cycle. Also i had noticed in the last few weeks when it did go through all the cycles, the clothes would still be partially soaked. iām not sure whether it was not completely draining or spinning thoroughly.
My washer will do the same as Gilberts, but I will have to run the spin cycle to get the rest of the water out. Could this also be caused by the lid switch and how can I test it to make sure?
Sorry for the delay. You have to remove the washer cabinet and the pump, and check the pump and hoses for a clog inside (the instructions are attached). Perhaps it needs a new pump.
