Kenmore 90 Washer won't spin or drain
Replaced broken lid switch, worked 6 loads and stopped again spinning or draining. Replaced water pump - still will not working. Switch does not advance - stops at rinse cycle and water stays in tub. Not sure what else to check?
Check that lid switch again. The first may have broken because of a problem and that problem may still be there.
By pass it where it connects from the console to be sure.
