My side by side Kenmore Coldspot has water accumulating in the bottom or the freezer floor section. Any ideas on what is causing it and repair of the same? Thanks. Wayne
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it’s stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
thanks. You are correct. It cleared it up. TY
