The 9" left front burner (with simmer select) on my Kenmore model 79096212406 cooktop quit working. The "element on" light comes on but it doesn’t heat up. I removed the burner and checked the element for continuity and it seems to be okay. All of the other burners are working just fine. Any suggestions?
Problem solved!
I swapped out two of the element control infinite switches that are the same to see if just the switch was bad. Apparently there was a loose connection, because all of the elements are working correctly now. Glad I tested the continuity and the infinite switch before replacing the $120 element.
