I have previous post on here dealing with this model not filling. I have model 587.14432200. When I did a parts search, this specific model # is not listed. Would anyone know of a comparable model # that is listed for parts? Also, I am looking for a sump gasket. The one I have is leaking. Also, it won’t fill completely. And I have water that is coming out of the drain hose while the unit is running. Any help greatly appreciated.
Which parts, besides the pump (sump) gasket, are you looking for?
It does not fill properly more likely due to a clogged water inlet valve.
The drain hose should be at least 20" above the ground level.
Thanks Gene,
I appreciate the info. I will order the parts.
I found out the leak was coming from the motor/pump shaft seal area. Is there amy way to just order the seal? I notice a lil’ side to side play with the shaft going into the pump housing. Is there a bearing that can be ordered also? I ran the part number of the motor and it only showed the whole assembly (pump and motor assy). Thanks for you help.
Yes, you can order just the seal assembly, but there are no any bearings.
- The seal assembly AP3209244
Gene,
Thanks again. I appreciate your help. Having problems getting the old shaft seal off. Any helpful hints? I don’t want to damage the pump housing or motor. Just about tried everything.
Very likely the motor shaft is rusted due to the water leak. Try to use WD-40 or something like that. If it would not help and the motor shaft is rusted beyond repair, the whole pump and motor assembly has to be replaced.
- The pump & motor assembly AP3885612
