Posted earlier about no draining. Figured out it was, of course, a plugged drain hose. Unfortunately I got underneath and unscrewed a bunch of stuff before I figured that out, so now the drain pump leaks. I took it apart and can’t get the O-ring to seal in between the two halves. Does anyone have ny tips, or have I ruined it by taking it apart? Should I just order a new drain pump? If so, I cannot figure out how to unhook it from the rest of the unit. There is one plastic tab that seems to be holding it to the unit and I am afraid I will break it if I keep trying to pop it out.
Related topics
| Topic | Replies | Views | Activity | |
| Kenmore Elite Oasis He leaks | 4 | 8708 | June 6, 2011 | |
| Kenmore won't drain, pump ok! | 0 | 1995 | January 17, 2008 | |
| Kenmore front loader won't drain | 3 | 2372 | July 23, 2008 | |
| Washer does not drain | 2 | 829 | March 12, 2010 | |
| Drain Pump Leaking | 2 | 1381 | April 27, 2011 |
