Our Refrigerator Ice Maker stopped working. It is a Kenmore Elite M/N 106.57706700 and was purchased 12/06 or 01/07. Within the warranty we had the problem previously and the repairman came out and said the board had gone out and replaced it. Now is has been about a year again and the same thing has happened; one minute it is dispensing ice and the next minute it is not. I have never seen an ice maker stop working this often. Is there something we can check or try?
I have an Estate washer. It will fill with water but will not do any thing else.
I’ve checked the lid switch and it is working fine (i.e. I used an ohm meter). I assumed it was the timer, because I would put it on a spin cycle or any other mode and it would not move, so I replaced it. The washer has the same failure mode. Any suggestions?
Does it drain when you put it in the spin cycle?
I would jumper the lid switch, sometimes meters give a faulse reading, or the switch will arc open when 115 volts hits it.
