Kenmore Elite Not Cooling
I recently found out that my Kenmore Elite Model 79572053110 stopped cooling the freezer, and the refrigerator. Here is what I did while troubleshooting. Opened fridge and freezer door, then held down "Ice Select & Refrigerator Temp" to put in demo mode "O FF", then turned off demo mode. Opened back panel at top, and pressed the little black button on the mother board once. Fridge beeped 3 times (all options on control panel at front lit up). Pressed it again and it beeped three times but as two consecutive beeps (Control panel went back to normal). Pressed it again, and fan turned off, and was as if it turned off the fridge. Repeating the pattern does the same. The times when it beeped, the fan ran inside the fridge, and it seemed like it was working, but the air wasn’t cold, I don’t really think so. The compressor makes noise, so it’s getting power, but I don’t know if enough. The compressor stops running with a kind off scratch noise, and then I suppose will start up again, because it’s running sometimes. There is an LED light on the mother board that blinks six times. The capacitor looks fine (no burns). I have unplugged it, waited 15 minutes or so, then plugged it back in. The coils are clean, the big fan back there is running. There have not been any error codes, and I’m sure that I did not erase by unplugging. The filter fan works. No air is being pushed into the fridge unless compressor is running, and that air is not cooled. I have a list of suspected part failures, but I need a veteran to tell me what the likely suspect is. Please Help.
